Streamlabs Desktop
Configure Streamlabs Desktop as a broadcaster in Streamer.bot
Navigate to Stream Apps > Streamlabs Desktop in Streamer.bot
Streamlabs Desktop Configuration
To add a new connection, Right-Click anyhere in the panel area and select Add:
Enter any name or label to describe this Streamlabs Desktop instance
Host
Enter the host address of your Streamlabs Desktop instanceIf Streamlabs is running on the same machine as Streamer.bot, keep 127.0.0.1For multi-pc setups you can configure this with another LAN IP address, e.g. 192.168.1.10
Port
Number required
Enter the port from your Streamlabs Desktop Remote Control settings
  • Default: 59650
Token
Enter the token from your Streamlabs Desktop Remote Control settings
Auto Connect on Startup
Automatically connect to this Streamlabs Desktop instance when Streamer.bot starts up
Reconnect on Disconnect
Automatically reconnect to this Streamlabs Desktop instance when the connection is disrupted
Retry Interval
Change the interval of reconnection attempts when Reconnect on Disconnect is enabled
Selecting a connected Streamlabs instance in the left panel will reveal additional realtime information about that instance on the right panel:
Shows the name of the currently broadcasting scene on that connection
Shows the status of current streaming and recording activity
Lists all sources present on the currently selected scene
