• Get Started
  • Guide
  • API
  • Examples
  • Changelogs
  • Sub-Actions
  • Triggers
  • C# Code
  • WebSocket Server
  • HTTP Server
  • UDP Server
  • Sub-Actions
  • Triggers
References
  • Sub-Actions
  • Triggers
Elgato
    • Get Filter State
    • Get Input Information
    • Get Microphone Information
    • Get Output Volumes
    • Get Selected Output
    • Mute Input
    • Mute Microphone
    • Mute Output
    • Set Filter Bypass State
    • Set Filter State
    • Set Input Volume
    • Set Microphone Balance
    • Set Microphone Gain
    • Set Microphone Output Volume
    • Set Output Monitor Device
    • Set Output Volume
  1. API
  2. Sub-Actions
  3. Elgato
  4. Wave Link
Set the output device of the monitor mix
v0.2.0
Set Output Monitor Device Dialog
Device
Select the device you want to monitor with
Set the output volume of a specific microphone
Set Output Volume
Set the output volume of an audio output
On this page
  • Parameters
Community
  • Edit this page
  • Chat on Discord
  • Support on Patreon
Ecosystem
  • Streamer.bot
  • Speaker.bot
Made by Streamer.bot
