TTS Delay
Is it possible to have a dynamic delay for the duration of the TTS?
Since Streamer.bot v.0.2.3 you are able to use the new Speaker.bot -> Speak subaction. This requires a websocket connection. Navigate to Settings -> Websocket Server in Speaker.bot and start the server. In Streamer.bot then go to Integrations -> Speaker.bot and connect it there. You can then check Delay on the subaction and the upcoming subactions will wait until TTS has finished. Checking the Delay box also populates the %duration% variable (ms).
Speakerbot Speak Subaction
