Obs Connection
Why is my Streamer.bot not connecting to OBS?
There could be various reasons for this, but here are some common solutions:
- Ensure that the Enable WebSocket Server option is enabled in OBS
- Ensure you have entered matching
IP,Port, andPasswordconfiguration in both OBS and Streamer.bot - If Streamer.bot and OBS are running on the same PC, use
127.0.0.1as the IP, otherwise make sure you are using the correct LAN IP address (e.g.192.168.1.x) - If you are trying to access OBS over an outside network, such as a VPN or tunnel, you should bind the OBS WebSocket server to
0.0.0.0 - If you are on the same network, you can consider deactivating authentication
- In rare cases, the default port
4455is already occupied, you can try changing it to something else like4456or1234 - Make sure you are using the correct
obs-websocketversion. If you aren't sure, you should selectv5.xon the connection configuration in Streamer.bot
